check_dlink_dgs
check_dlink_dgs is a Nagios / Icinga plugin for monitoring D-Link DGS managed switches.
The plugin checks for disconnected ports and also gathers package counter metrics which can be exposed as performance data. The switch is connected via SNMP (version 1 or 2).
Requirements
The plugin requires Python 2.6 or newer - it also requires the pysnmp module.
Usage
By default, the script checks particular ports for connectivity, it is also possible to auto-detect available ports and check all those ports. The script also supports performance data for data visualization. The following additional parameters can adjust this behavior:
| Parameter | Description |
| -d/--debug | enable debugging outputs (default: no) |
| -h/--help | shows help and quits |
| -P/--enable-perfdata | enables performance data (default: no) |
| -H/--host | defines the switch hostname or IP |
| -c/--snmp-community | defines the SNMP community (default: public) |
| -V/--snmp-verions | defines the SNMP version (default: 2c) |
| -p/--snmp-port | defines the SNMP port (default: 161) |
| -P/--ports | defines one or more ports for monitoring |
| -a/--all-ports | monitors all ports (default: no) |
| -A/--active-ports | monitors all active ports (default: no) |
| --version | prints programm version and quits |
Examples
The following command checks a particular port for connectivity:
$ ./check_dlink_dgs.py -H 192.168.178.1 -P 1
OK: All specified ports connected |Checking particular ports by ranges, customized SNMP community:
$ ./check_dlink_dgs.py -H 192.168.178.1 -c giertz -P 1,3 -P 4-5
OK: All specified ports connected |Gathering performance data of a dedicated port:
$ ./check_dlink_dgs.py -H 192.168.178.1 -P 26 -e
OK: All specified ports connected | 'inOct ESXi/10G'=577123318111 'outOct ESXi/10G'=1269140449325Checking all available ports:
$ ./check_dlink_dgs.py -H 192.168.178.1 -a
CRITICAL: Disconnected port(s) 2,7,14,15,16,17,19,20,21,22,23,28 |Checking all connected ports:
$ ./check_dlink_dgs.py -H 192.168.178.1 -A
OK: All specified ports connected |Configuration
This repository contains a NRPE (check_dlink_dgs.cfg) and Icinga2 (check_dlink_dgs-icinga2.conf) configuration example - take a look!
